Many thanks for your reply, i'll give you the info. i have on the cam card.
part# 34-772-9, grind# ff xr286 r-10, gross valve lift .664 exh. .671 intake duration @ .015, tappet lift 286 intake 292 exh.
lobe lift .3840 intake, .3880 exh.
hope these specs help.....
i'm planning to remove the intake and take out and inspect the lifters for my own piece of mind. if all is well i'll put it back together and go from there. eric at performance eng. built the motor and i think did a great job. again thanks for the feedback. i REALLY appreciate it....
john
