Old 02-15-2004, 07:45 AM
Bud Man's Avatar
Bud Man Bud Man is offline
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Luke:
Important to keep in mind that if you are running an MSD type ignition box a spiral wound wire - not solid core - is mandated. Aftermarket wiring was one of the few concessions I made to underhood authenticity on 142. I finally settled on Accel 8mm Superstock black wiring.
If you use the stock plastic standoffs on your pentroofs, you will need to radius the openings a bit to accommodate the 8 mm as they were designed for the stock street 7mm wires. My original MSD wires were 8.5mm and were just too thick.
Bud
