Clois Harlan Clois Try a Titlon Bearing PAW, Jegs, or Summit. What is the problem that you are having? You have the right depth for the bearing to the pressure plate? You have stops for the clutch pedal to not over extend the bearing?? If the lines are leaken change to elbow fittings. Make your own. If this is not working, try George A system and go with an AUTO
At lease you will not start out in 3 gear and smoke the clutch. Only kidding
All you have to worry about is the RED LIGHT Problem
Rick Lake ps Call Lew is he having this problem??
