Old 02-17-2004, 08:25 AM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
John - that cam is sorta right on the edge of what I would run on the street. I think I would use that bumpstick and switch over to hyd. rollers though. That is, if I were planning on taking that car out on any trips. You will most likely have to replace the rockers every 2 or 3 years. I keep another set around, then when I pull them I send the old ones in for a rebuild that rotate back in the motor later. Don't let anyone "tune" your rockers (intake ports) by going to a 1.6 rocker with that bump stick. I assume you have the standard 1.7's on there now. If you get a rich or lean runner I would change intake manifold. Sounds like your good to go, and Eric enjoys a good reputation on this board for well built engines.
cobrashock
Ron Shockley
