Thread: rear brakes
Old 02-18-2004, 12:25 AM
nanard289 nanard289 is offline
Cobra Make, Engine: Cobra Daytona (from USR) 302RDI Yates headed + Weber induction
Question rear brakes
Hi Kajun,
Do you have a limited slip rear end? If yes, you have to lift both rear wheels before to try to spin one. If not you have to remove the brake pad set to be sure of the cause (it can be also a too tighted roller bearing).
Good luck for your investigation.
Bernard
