Todd,
Are you set on going with 5 point? We were going to go with 5 point, until we realized that we would either have to find a seat with a hole in the cushion, or run the sub belt around the front of the seat (less than ideal). In addition to that, you would have to make an extra hole in the floor to mount the sub strap. With 6 point, you can avoid both situations. Either sub belt bolts to the same point as the lap belts and comes up and over the side of the seat. It's not much of a hassle, and is quite comfortable.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
