PCV valve with Webers?
Can you hook up a pcv valve with weber carbs?
I have a pair of cast aluminum valve covers I'm going to polish and plan on running webers. One side has a hole for a breather tube and the other has a hole for a pcv grommet. If a pcv valve can't be used with a weber set up, then I'll bore out hole for the pcv grommet and add another breather tube.
 Snakebit
