Scott
We just installed some adjustable Pro Shocks on my brothers car and it made a big difference...... and especially depending on the spring rate..... and that changes all of the time.... until you get the chassis working the way it is suppose to .....
Is it worth it to have Double Adjustable shocks .... Yes.... if you are trying to go fast... if you just cruising.... it doesn't matter.... as long as you got the shock and spring matched.... it even made a difference for his crusing mode...
He had the standard Pro shock and it was to stiff for the springs he was running.... but when we changed over to 17" wheels we stiffened the springs and will have to adjust the shocks again...
Things never stay the same.....and I would say change is good...
if you're looking for speed and time
Morris
Morris
