Thread: Sunshine & $hit
Old 02-23-2004, 04:52 AM
hcollado's Avatar
hcollado hcollado is offline
Cobra Make, Engine: Everett/Morrison- Boss 302 Stroked W/351W heads and a whole bunch of ponies
Smile
Randy, this may be a lot simpler than you think. Last fall Tony and I went up to the Dillard house for lunch and on the way back, the little red car started stalling and doing the same things you described, minus the green stuff leaking into the footbox.
I replaced the whole fuel system, electric pump, new filter, new line and new regulator.
But I think what was causing the problem was the gas cap. It was pressurizing the system and causing a vapor lock. Try a new one before you go thru a lot of work.
Good luck
Hector Collado
Everyday is a Holiday ... every meal is a banquet.
