Old 02-23-2004, 04:36 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
I think Starwolf56 has got it. Oil pressure unit is on drivers side. possibly a leak in the line. Could be a crack that only opens when the pressure is enough to spray out instead of drip. If you have the Autometer gauges, you have mechanical feeds, it would be the line. If you have VDO it would be the sending unit.
Good luck, but I think you have the answer.
tfarhood
