Thread: Hi Stuart
Old 02-23-2004, 06:43 PM
pneall's Avatar
pneall pneall is offline
Stuart.
I am impressed , you are going with side pipes at rego??
I keep hearing conflicting information as to whether side pipes are legal or not. Apart from the noise factor I believe there is now a pedestrian safety issue with exhausts pointing towards gutter.
Suppose you could point the ends down for street use and rotate them out for track use.
What method of construction are you considering. I am following Mike murphys design although will probably go for smaller primaries to keep low down torque.
I am using 2.5 " perf tube covered with sound deadening then wrapped in Thermal blanket. All will be demountable so the cat can be serviced.
I would appreciate you keeping me informed of how your side pipes work out.
Regards,
Phil
