Old 02-23-2004, 07:54 PM
Dirty Harry Dirty Harry is offline
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
If you're running a mechanical fuel pump and the bolts come loose, oil can escape between the engine and the pump flange. (I know from experience.) The car may run fine until the pump gets so loose as to nearly fall off. Check those bolts and the gasket.
When I said I wanted to be somebody, I probably should have been more specific...
