Bruce,
Can you give me more info on your engine?
>It's a 350 bored .30 over with TRW forged pistons. I'm running the Edlebrock Performer RPM cam: 296/300, 234/238 @ .050. lift .539/.548, lobe separation 112. I have found that Rhodes lifters smooth out the bottom end a lot.
What kind of gear are you running in the rear?
>It's a Jag 3.31 rear end. The Tremecs 5th gear is a .68 overdrive.
The black car in my picture gallery is pushing 400+ from a 30 over 351W. It is running a 750cfm and cruises at 70 in fifth turning 1250 rpm with the AC on. If you drop it into third gear and step on it it will tear your head off.
>Sounds perfect! Do you recommend the Avenger carbs?
Paul
