Originally posted by brainsboy
I bought a motor once that was putting out 100psi oil pressure. I ran it for about 2 years that way before rebuilding it. I noticed that someone had changed the spring in the oil pump to put out more psi. The motor was in great shape when i did the tear down, bearings looked good. Why dont they make pumps that have 100-120 psi normaly? Would there be any ill effects from doing this kind of psi with all performance motors?
Yes, there are ill effects from running too much oil pressure. Look at a bearing chart, they usually have a picture of a main bearing that has holes in it's babbit from too much oil pressure. Not to mention that extra work your timing chain has to do. And you can't puch that much oil through a motor, it just squirts out the pressure relief on the pump. Your motor is working extra hard to build all the excess oil pressure, and it just gets sprayed out a relef valve.
