Thread: Engine Sensors
Old 02-25-2004, 08:52 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Joe-
One piece of advice which I picked up here. On the oil temp sensor, do not use teflon tape on the threads, it may prevent a proper ground and cause irratic readings. Get some of the teflon paste instead.
Also, if you are using the remote oil filter, the block adapter has a port built into it to hook up the pressure gauge.
Replica is not a dirty word.
