David,
If you have more than about 580 lift at the valve I believe you have to cut the pistons for clearance because of the valve angle change. The valve angle may make some other valve train changes necessary as well for the push rods and rockers. The good news is that new heads are supposed to get you up to 90 HP over the old design.
