Thread: 306 questions
Old 02-26-2004, 05:57 PM
blykins blykins is offline
Here....I worked a little something up for ya....
306 ci
4.030" Bore
3.000" Stroke
AFR 185 Heads, 2.02" I, 1.60" E
10:1 CR
Single plane intake manifold
650cfm carb
Comp Cams Xtreme Energy Hydraulic Flat Tappet Cam
250/256, .554/.558 110LS
Peak HP 411 @ 7500rpm
Peak Torque 348 @ 5500rpm
But....you don't have any power at all until 4500 rpm....and that's 277 hp. The torque there is only 323 lb-ft.
But that's what you face with a small displacement engine. I think it would be easy to build this one....quality parts are imperative. However, streetability????? I guess if you had a real low tranny gear ratio and a real low rearend ratio it wouldn't be that bad.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
