Old 02-26-2004, 06:40 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
From what I see you have a set of 289 65 heads. The casting for the block is on the side of the block and cast in to the block. It is pretty big and you should not have any trouble finding it. Sorry I did not check on one of the blocks at the shop to see what side it is on and I just do nto remeber right this moment. I do know that under the intake it will show the size cast between the lifter valley but you do not want to pull the manifold.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
