Thread: 306 questions
Old 02-26-2004, 11:21 PM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default street 7500...why?
You say this a "street mainly" car you are building?
How did you get fixated on "7500 RPM" as the way to go?
If you have to ask...you DO NOT NEED IT!
I have an ERA 289" FIA car with a 65' 289" block, Tremec TKO, 3:55 rear end, 15 inch wheels.
It sees 90% street, 10% open track at Willow Springs and Button Willow race tracks.
I wanted the small 289/302 block as its about 30 ~ 50 pounds lighter than a 351, and in my eye, with the lower deck height, ( if only about 0.80 inches), it looks right in a 289 replica.
Ok, so I got the low weight for optimum handling I wanted...it has aluminum heads, Trick Flow with 2.02 intakes, dual plane aluminum STREET intake, Weiand Stealth, 750 Holley dbll pumper, too big probably...aluminum water pump, aluminum flywheel...not much left to do there short of a aluminum block.
The engine has been stroked...it is at 347"...there is a "girdle" on the main caps...the rods are Eagle, the crank is steel, the pistons Ross forged, the cam is a hydraulic roller, very mild, 224/228, (sort of the Ford Motorsports X cam), but a lot of lift, about 0.55 plus or minus intake/exhaust.
Now, the rotating parts are overkill for my power, but I NEVER wanted to never look at a hole in the block due to missed shift.
The compression ratio came out too high at 10.7, (long story there!), but seems to work with out detonation if you always shift down...should have gotten more cam overlap or less piston, oh well, next time.
( do not do the too high compression for a STREET Engine...!!)
I put a 6000 rpm chip in the MSD to act as a safety valve, it could go to 6500 at least I think even with a hydraulic roller.
But...it has more power than I can use on the street...unless YOU are midnight racing for pink slips...what do you need on the street?
If you are NOT an ACTIVE ROAD RACER, a ACTIVE BRACKET DRAG RACER limited to a certain displacement by rules, or looking for a land speed record, why would you want a high RPM, HIGH HORSEPOWER and LOW TORQUE, life limited engine for the street?
The old saying, "there ain't no replacement for displacement" seems to be true especially for the street.
Ask your self again...what you are going to do with the car?????...how long does it take to DRIVE to the freeway much less an "open track event" for a road race course...?
You could argue that a 331 or 306 would live longer as the piston pin is lower, out of the oil groove, piston speed more reasonable, but if this is a STREET engine, how much time will it be screaming at 5000+?..
As practical matter...a 347 theoretically may last half the time of a stock stroke or 306/331 stroke due to piston speed and ring placement...
I have driven my Cobra about 5500 miles in a year and 5 months...at that rate, its got a FEW years left...and as my skills improve, maybe I will put in a little more cam duration/overlap for power and to kill off the compression ratio, and freshen up everything else at the same time...
Short of a blown cylinder side wall due to side loads, not much to go wrong on an understressed bottom end.
For the STREET, ...TORQUE is what makes it accelerate...from a stop light or a rolling 30 mph...
HORSEPOWER GIVES HIGH TOP SPEED...
Gonna do 140+ to the next off ramp?
The speed limit around here is 70 max, and I have to row the gears for 30 minutes to get to the freeway anyway.
If you are NOT OBSESSED with handling, (like ME!!!)...go with a 351 stroked out to whatever...they seem to do well over 400 inches even on the road race stuff... make LOTS of TORQUE...and you wanted ACCELLERATION?????
.After reading a lot of website posts, magazines, bragging....and living my own automotive dreams, if you GOT TO ASK what you need...you DO NOT NEED the super wazoo 7500 RPM stuff...!
OK, you are gods gift to racing...in a season or two, if you build a GOOD bottom end, you can swap the cam and valve springs, etc. etc. etc. and get your high revving engine without too much trouble.
These cars are light, traction limited, short wheel base squirrels...in a road race situation, they can be a handfull...a lot of the guys here at the web site seem to be very active and experienced amateur/pro racers...I'm not!... but learning!...
So, again, what are you going to USE the car for in its FIRST incarnation...?
Hope this essay doesn't sound condescending, but I think you can have MEGA fun in a 2400 lb car without fantasy power that is a pain to drive in traffic.
Keep posting questions, you will get a million different answers...untill you know what you want to do, and how to get there, don't spend your money.
Pete
ERA 289 #2027
