Old 02-27-2004, 05:18 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Lyn,
You are going to have trouble. The 96 Mustang came with PASS system that will not let you start the car with out the correct key. It shuts down the ignition and fuel system. You could use an earlier computer with out the PASS system.
We ran into the same problem with our car using the Mustang computer that comes with the supercharger system we got from Ford for our 4.6 set up.
We ended up having a chip burned for the computer to bypass the lock out. They only got half of it correct and we had to run a wire to turn on the fuel pump.
It can be done but you may wish to get an earlier computer to bypass all the trouble.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
