Matt
If you go with FFR the 302 will be the most economical choice as it will probably come with the donor, otherwise get a 351. It's stronger and there's no substitute for the extra cubes for roughly the same $$ for a decent used motor. In fact you may find the 351 to be cheaper. From that point on any money you invest in either motor will yield greater proportional gains on the 351. Again no substitute for cubes.
Mike
