Old 02-27-2004, 10:35 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Arrow
Hi,
An easy way to lower compression is to get later heads. You probably have heads with 72 cc chambers, later heads are 92 , 95 or 97 cc's. This will lower compression between 1 and 1.8 points, depending on your starting point.
I run 98 cc open chamber heads and a flat top piston, this will give the best flame travel.
Perry.
