Thread: header problem
Old 02-28-2004, 11:16 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Check your local speed shop. You can pick some up header bolts with a snap ring that you install after the bolts are on and tight that will keep them from backing out.
Always use a good header gasket not the cheap ones that come with most headers. The good ones will only shink a small amout were as I have seen others get very hard over a short time and blow out as they get smaller.
As far as gaskets go you get what you pay for and that really shows up on header gaskets!
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
