I'll call my son and have him sort out the computer .I'll try to copy the diagram that Enzo sent with the switch.
The electric socket on the motor has five lugs, four verticle ,one horizontal
_ ground
I fast I park
I slow I fused ignition 12V feed
The top horizontal is a ground.Upper left verticle is fast speed,lower left verticle is slow speed,top right verticle isthe park from motor to#4 terminal on switch,lower right verticle is a fused 12V. I'll probably run the fused 12V power supply to the switch and back out of the same connector the supply to the motor .
Switch
1__ __2
3__ __4
5__ __6
7__ __8
#2 is Park returning from motor,#4 is fused ignition 12V feed
#6 is slow speed ,#8 is fast speed no blades in #3 and #5 on switch
I'll work on the diagram but I thought I was clever tring to make this display with what I knew.
Mike H
