Old 02-28-2004, 11:16 PM
Keithc8 Keithc8 is offline
Default New 427 Side oilers complete of dyno
If you ever wanted to have a new 427 side oiler FE engine there is no better time than now and with better parts than ever.
New Genesis cast iron blocks, pressure checked with all CNC block machine work second to none. Scat cast steel crankshaft, Scat 4340 H-beam rods, Custom JE pistons for application, Plasma Moly rings, Federal Mogul bearings, Electronicly balanced, Ford Racing double roller timing set, Comp Cams hydraulic roller camshaft, Crane hydraulic roller lifters, Melling HV oil pump, Armondo original style oil pan, windage trey and pick-up. Stock aluminum front cover, stock damper sleeve, BHJ new SFI approved damper, Edelbrock aluminum water pump, Smith Brothers .080 wall pushrods, Edelbrock Keith Craft stage 2 CNC ported heads, Erson roller rockers, Edelbrock Performer RPM intake, choice of valve cover[Shelby, Ford Racing, Chrome Pent Roof], DaVinci 950 HP carburetor, MSD distributor and gear, Ford Racing or MSD plug wires, NGK spark plugs, McCloed aluminum flywheel, MSD 6AL box, MSD blaster coil, Blueprint assembled with build sheet provided, painted and detailed, Dyno tested and tuned. These engines can vary in size from 431C.I.{with a 390 crank} all the way up to 496C.I with 4.310 bore and a 4.250 Scat cast steel.
This complete package for 14,995.00. These engines will produce between 550 and 650HP depending on the size, compression and camshaft used.
There are upgrades available
Billet Scat or Valasco cranks add 1600.00
Billet Lunati Rods add 700.00
Shelby Aluminum block 2000.00
Genesis Aluminum block 1200.00
Keith Craft Stg3 CNC heads 1000.00
Shelby big bore block 2500.00
Call with any other options needed.
We do have three more genesis cast iron and one aluminum blocks available right now with more on the way.
Still waiting on Shelby blocks, have ten coming and seven pre-sold.
Don't miss out on this special chance to own a new FE engine that will performe like it was suppose to. If you want an FE that idles at 800RPM's but is still capable of 600HP here is your chance.
Fell free to give me a call at 870-246-7460 or e-mail me with any questions. Thanks Keith Craft
Keith C
