Nantucket,
See my gallery for pictures of motor. It is a 428, has edelbrock aluminum heads, intake, waterpump, Aviaid pan, etc, most of which is powder coated silver with a clear coat. Cam is a comp cams solid lifter. Rocker setup is Erson. Heads have had a stage 1 port job.
Oil pump by Precision Pumps. Will have MSD ignition and Holley 750 carb, yet to be installed. Has aluminum flywheel and a blowproof bellhousing. Rotating assembly was all balanced. Ie, should have plenty of power!
Joe
