Old 03-01-2004, 06:14 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
If you have an adjustable valve train ( for the 302 that would be something installed, not stock ) you do the first method.
If you have the stock valve train and the rockers are on posts, you do the later.
Check your heads for sloted holes that are a hair bigger than the push rods, that will most likely be the torque down version.
Hope this helps.
