Old 03-01-2004, 01:36 PM
HotRodJoe HotRodJoe is offline
Cobra Make, Engine: Kirkham, Pond Aluminum 482FE
Nantucket,
The Performer RPM has an embossment behind the carburetor to put a PCV in. I drilled a hole in that embossment the same size as the one in the valve covers and am going to use a regular valve cover grommet and PCV in that back manifold location. Right now, there's just a piece of masking tape covering the hole until I hook all of that up. I've seen different things done, including putting a breather in that location. I thought this would look cleaner because the hose from the PCV would just come up to the back of my carb instead of laying across one of the valve covers.
Joe
