Old 03-01-2004, 02:16 PM
meangreeny meangreeny is offline
Cobra Make, Engine: B&B 186 351w
Default B&B 186 For Sale
For Sale
2001 B&B Cobra (B&B 186). Color: classic silver (solid – no stripe).
This cobra was professionally built in 2002 and has only 1150 miles on it. It is an outstandingly reliable and beautiful Cobra with all the upgrades:
Tubular Front A-Arms suspension.
Four wheel disc brakes with 11inch upgrade in front.
Adjustable proportioning valve – brakes.
Carrera coil over shocks.
Auto Meter Cobra replica gauges with reverse speedo.
T-5 Transmission.
Scattershield.
8.8 Ford rear end with upgraded 3:73 gears.
Heater.
3” Simpson race belts with camlock.
Under the hood:
Professionally rebuilt and balanced 1971 (D1AE) Ford 351 Windsor block by ADC Racing.
The car has never been on the dyno but I suspect it will bring between 350 and 385hp.
Erson High Boost Performer Cam.
Bored over .030 with torque plate. Line Honed.
10.25:1 compression. Will run on pump gas (i.e. 91 to 93 octane).
Edelbrock 600 cfm carb. with elec. choke.
Edelbrock Performer intake
ARP Rod Bolts.
Milled Heads, ported bowles, race valve and head job.
MSD Distributor & Coil, MSD 6AL electronic ignition. MSD plug wires.
Crane FMS Roller Rockers – no adjustment required.
Heavy duty gear reduction starter.
Mellings Oil Pump. Airtex water pump.
Cobra Valve covers. Edelbrock air cleaner.
Miscellaneous items:
Complete build photos available. Car never raced.
I had a 71 block re-built for emissions purposes. Current Colorado Kit/Replica car requirements for emissions are set at the regulations that were required during the same year as the engine block so in this case – 1971. The car has passed inspection at the State Patrol, Department of Health and emissions. Car is registered and titled in Colorado as a 2001 kit car.
I have over 43k invested in this car.
Price: $39,000
Will sell for $32,000 less engine, all MSD ignition components and transmission.
Please call David at 720-933-5111 for enquiries. Car is located in central Denver.
