Thread: wiring ?
Old 03-02-2004, 05:52 AM
charlieb62 charlieb62 is offline
Cobra Make, Engine: ERA #664 finally done!
Default wiring ?
Maybe I'm thinking too much but when wiring in the MSD Didital6 plus, you are supposed to connect the #43 resistor wires together then connect the msd red wire and the tach output to #40 connections (original coil) this also eliminates the need for the white wire on the solenoid. My question is can I connect the tach out directly to the signal terminal on the tach,and the red wireon the msd directly to the ign switch disconnecting the green wire presently there, then I wouldn't have to worry about running a harness out the old coil connections. Thanks for any help. Charlie B
