Ron61 - If you have access to this program run mine if you will. I've had mine engine dynoed and would be interested in knowing what the software suggests I should have.
Engine specs:
427 ci
.591 solid lifter cam
roller rockers
.55 & .60 duration @ .50 lift
victor intake
825 mechanical secondary carb
11:1 compression ratio
edelbrock heads 70cc chambers if needed
2.19 in & 1.73 ex valves
3.781 stroke
electronic ignition
port matched heads & intake
Need anything else?
Thanks to you or someone else who can run this!
