The 16 gal Jaz cell I installed has a sender and center sump/pickup that actually hangs down between the framerails and I don't go racing with a full load of fuel in the tank, who does? plus the foam bladder minimizes any fuelsloshing my 5 gallons may attempt during raceday. I initially used the Jaz filler neck hooked to the LeMans cap and still had enough room for essentials in the trunk. I only did away with the cap being functional because of my hangups with dripping fuel on the paint and the stupid springloaded filler nozzles that were always trying to take a bite out of my bodywork. Also, the bottom part of those handles comes way too close to the body for my liking. The only person who knows my cap is a showpiece is me, you and anyone else who reads this. Even when someone pops the cap they can't see past the springloaded flap in the fillerneck. When I had the Jaz filler on the cell it I faced it toward the right rear corner of the trunk and fabricated the filler tube so it was low and out of the way.
"If you're not racin' it, you're wastin' it!"-Me
