Old 03-08-2004, 07:58 PM
dlowe01's Avatar
dlowe01 dlowe01 is offline
Cobra Make, Engine: RU Carcrafters / 408 Stroker
Yes, I pulled a valve cover and the rockers had plenty of oil on them. I did put the comp cams assembly lube on the gears at build up. Another question that is probably not related to the oil problem is I know I have seen before in some other posts about people having problems with there distributer gear wearing out very quickly because it is not compatiable with the cam. Do you know anything about that???
