Old 03-10-2004, 01:33 PM
bmalone's Avatar
bmalone bmalone is offline
Default Contemporary w/ 427 TP
Bill Malone's car.
CCX-3-3346
Per many of the recent threads where we all try to guess the price or auctionability of various cars, I prefer not to disclose the price. I can say this: it is not unreasonable and I think the right buyer will be very pleased with the car.
More pictures in my gallery. Be happy to send additional on request. My e-mail address is bill.malone@netzero.net.
Red Contemporary, built in 1992 by Don Borders. Sat unused for many years. I bought the car in April 2002. It had 3000 miles on it at that point and I have put approximately 9000 more on it myself. The motor has now 12,000 since rebuild.
Engine
-1966 cross-bolted side-oiler block (C6AE-H)
-Forged steel Le Mans crank
-Le Mans rods
-9.6:1 Compression ratio
-Crane custom-ground cam
-Ford NOS tunnel-port heads (C7OE)
-Ford NOS tunnel-port 2x4 single-plane intake manifold (C8AX)
-(2) Holley 750 vacuum-secondary carburetors
-Accel dual-point distributor
-Ford Pentroof valve covers
-Canton 8 qt. Roadrace oil pan
-Aluminum flywheel
-Melling high-volume oil pump (40+ lbs. at idle, and 78 lbs. above 2000 rpm)
-Dual remote oil filters with high-flow cooler
-FPP roller rocker arms
-New Manley push-rods installed Feb. 2003 (entire top-end gone through and reconditioned, one valve replaced)
-New valve guides installed Feb. 2003 (engine consumes NO oil)
-Improved air induction system Feb. 2003 (have original Stellings and Hellings tops)
-Howe 3-core aluminum radiator
-Edelbrock high-flow polished aluminum water pump
-16” electric puller fan (1900 cfm)
Exhaust
-New sidepipes Feb. 2003. Jet-hot coated in polished aluminum finish. 3” collectors and racing mufflers.
-Sounds awesome!
-Jet-hot coated exhaust headers
Drive train
-Ford CR top-loader w/ big input, big output shaft
-Close-ratio transmission
-Transmission rebuild in summer 2003 (all serviceable parts replaced)
-3.54 Jaguar Salisbury rear-end
Chassis
-Polished aluminum trunk
-Polished aluminum engine compartment
-All suspension parts either powder-coated or chromed
-Jaguar front suspension with coil-over shocks
-Jaguar independent rear suspension with quad Aldan coil-over shocks
-Jaguar inboard rear brakes
-Kevlar semi-racing pads up front
-Trigo pin-drive wheels
-Halibrand knock-offs
-BF Goodrich T/A Euro Radials—265x60x15 front and 305x50x15 rear
Interior
-Smith’s gauges
-Wilton wool carpet
-Connelly leather seats
Bill Malone
Gashole
CSX4786
