Old 03-11-2004, 05:34 AM
CobraV8 CobraV8 is offline
Originally posted by mrmustang
Simon,
Without a long disertation I cannot list the numerous differences of each engine...Instead, I would suggest that you post the casting numbers for the block and heads here, so we can properly decode them for you...............
Sincerely,
Bill S.
This sounds good, I think the FE block casting numbers are located on the front passenger side of the block and below the oil filter adapter on the front driver side of the block (casting date). Is that correct? Where are the head casting numbers located?
Where can the casting numbers be found on 385 series blocks and heads?
I'll have to tell the seller where to look for the numbers, I'm sure he doesn't know where they are located...
