Thread: A&C kit cars
Old 03-12-2004, 05:54 PM
Double Venom's Avatar
Double Venom Double Venom is offline
OK,OK, first off, we do use 600 on clear coats prior to second coating and NO sand scratches. "X", we're talking Gel-Coat here, not base coat paint. Again, on a colored gel-coat you wont get sand scratches if done right.
Second point, I think everyone is reading my post wrong. A&C's Gel - Coat finishes are great as is! (Cehck out Roscoe's Gel!) But, if you want it to even look better,.....then opt for the clear coat finish. Even A&C has/had done this to some of their "show-off" cars.
Not a paint Rep., but I've been painting and fiberglassing for over 30 years....and I didn't spend a night at the Holiday Inn!
Ed "DV" Combs .....as David said...always use a wet-sanding pad!
