Old 03-14-2004, 06:23 PM
Dave Engel Dave Engel is offline
Red, you are going to have to pull the hole motor, If you can't pull the lifter out chances are the lifter was not turning and thats why the cam lobe failed. Small particules from the lifter and cam get caught up in the windage and coat the piston skirts, chances are you will have to hone those cylinders again if you have room.
There are alot of people running cam lube on the lifter bores during assemble, this causes the lifter to not rotate and will cause cam failure. Did you get a dyno sheet? This should have been found. hope this helps.
Dave
