Old 03-15-2004, 05:17 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
It could just be a bad install. It's not like it couldn't happen.
Mike makes a good point, If it is not square to the crank shaft, it will leak.
Who's crate did you get it out of, Ford's or an engine builders? Does it make a diff? Yes.
Check the balancer, the housing to the crank and the seal itself. For that matter, make sure it is the seal and not a gasket in very close Proximity.
Just a thought.
