You will enjoy the Base Coat Clear Coat system best. A dark color loves the clear coat. You can do so much with clear coat, 3M has amazing products that your painter can use to work out the finnished clear coat. They have a system that the painter will use to sand it out, one grit is 1500 and then 3000. Then anytime a scratch gets in the clear coat, it is a simple fix. Clear adds a depth to the paint, have a few extra coats added for good measure.
