Hi Art:
I see you are up very early this morning. Thanks for the feedback.
Yes I intend to use black sidepipes. I intend to have a silver stripe that is the same color as the original. I had toyed with the idea of an all black car but decided to nix the idea as I already own a Buick Grand National which is all black so to go all black with another car would get monotonous. The heads and dual plane intake are Shelby with Shelby stage II porting. The following is the list of other stuff: Shelby Signiture Series roller rocker arms, Shelby timing cover, Shelby valve covers, Shelby double roller timing set, Shelby water pump, billet aluminum pulleys, forged pistons 10.5:1 compression, hydraulic roller lifter cam, forged H-beam connecting rods, steel crank with 4.125 stroke, blue printed
oil pump, breakerless, distributor, Aviaid Cobra
oil pan with windage tray, remote
oil adapter, Cobra oil filter and fabricated mount, installed with fittings. Engine will be blueprinted & dynoed by Shelby.
I appreciate your thoughts and look forward to continued dialog as I progress through my Cobra project.
Best regards, Mike
