Old 03-15-2004, 05:50 PM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
I might have... I still need to take it for a test ride. Nothing was bent. The pivot point that the arm and float moves on was very tight. This would cause the arm and float to move to the top of the tank when filled with gas and basically stay there. I loosened up the joint so it moves more freely. The only problem with my solution may be the gauge may fluctuate to much as the gas moves around in the tank.
I guess I would rather have my gauge fluctuate a bit rather than not move at all. If you ask me the mechanism is not well designed. If the arm is to tight it will get stuck and if it's to loose it will cause the gauge to fluctuate.
I manually moved the float and the electronics works fine. Just be careful working around the gasoline fumes!!
There may be a better fix out there. Any suggestions...
Jim
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
