  #116 (permalink)
Old 03-16-2004, 12:40 PM
BPWilliams's Avatar
BPWilliams BPWilliams is offline
Cobra Make, Engine: none
Default Sheared Dist Pin............
I have done that twice on my motor, I have a Unilite and it seems to eat the roll pin? once out in the middle of know where (desert) I had to pull the Dist and fix it in town, re assemble and drive off. any thoughts on fixing it? I have up to 75 psi oil pressure when cold 60 when hot. I do not want to put a solid pin in because that is the weak link.
Let me know if you find out what is causing this....
Keep it above 100................
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
