I recently went to a SCCA event and took my cobra with a street setup and did not do as good as I thought. Does anyone have a track setup (caster and camber setup) that could still be street friendly and handle the way it should on the track. I have a solid axle rear and adjustable springs and shocks all the way around. I had 28 pounds of pressure in the tires which after a lap I took the pressure down to 22 pound. The car would push into the corners bad and if any corrective mearsure was taken such as let off the gass completely or press any brake the rear would come on around. I guess I want to correct the push. Any suggestions would be greatly appreciated. Thank you
