Old 03-18-2004, 05:24 PM
ByronRACE's Avatar
ByronRACE ByronRACE is offline
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default Vortech Mounts...
I'm designing vortech mounts for the 385 series that mount the supercharger front and center on the engine where the water pump used to be. Instead of a mechanical water pump, you use one of the new mezeire electrics. The brackets use a reverse rotation V1, V2, or V7 series blower (I'm using the V7-JT), and are designed for 55mm cog drive, though you could use serpentine and adjust things if desired.
The blower discharge can be routed to a front mount intercooler or simply wrapped around to an intake manifold any way you like. I'm using a dominator style carb intake converted to EFI, with a custom elbow/hat that uses an oval throttle body.
In any event, this will be an easy fit in most cobras running 385 series motors...if you're interested, I'll provide more info as soon as I get the plate back from the waterjet shop in a few weeks.
With a V7-JT, you should be able to make about 1000-1100hp. We'll see.
Byron
