03-19-2004, 07:25 AM
KY
I checked on Autozone's website last night.....and did a couple comparisons...There are two ring gears available for the MII...6.75" and 8". They have two separate part numbers for the inner bearing. The outer bearings and seals are the same. I also did a check on the Granada wheel bearings...they have the same part numbers as the 8" MII bearings...so they should work as long as the bearing set is from an MII with an 8" rearend.
I input both cars as 1978 models...both with 302's. I guess it should be fine. I'm glad I bought the bearings for Mustangs other than 6.75" ring gears...
