Old 03-23-2004, 08:50 AM
mzhun mzhun is offline
Cobra Make, Engine: B&B, 396W Southern Automotive Stroker, Custom 8.8 by Fabrication Concepts
Thanks for all of your feedback. Here are some of the answers to your questions:
Cam is a Comp Magnum cam 292 lift and 534 duration
Oil pump is standard high volume replacement with mesh screen that gives me 50 psi at idle and 60 above 2000 rpm.
I am running Castrol 5-30.
Gear in this dist. has been on roughly 1500 miles and wear pattern is right in the middle of the gear.
Dist. ktightens all the way down.
Not sure if the block was decked, as it was built before I got the car and I am still trying to get the build sheet from the previous owner.
Matt
