Old 03-23-2004, 09:06 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally posted by Rick Parker
MZHUN:
The decking of the block with a 289/302/351 does not affect the meshing of the gears as stated above (sorry Chappy), The installed manifold hieght has no impact on the distributor fit.
Rick
Rick-
Can you explain why this is so? If you deck the block, haven't you in effect lowered the height of the manifold, and then necessarily, shortened the distance between the pump and the manifold? I noticed you said that it is the case wth the SB, what about with FE or 385 series? Curious . . . .
Replica is not a dirty word.
