Old 03-24-2004, 11:27 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
go to the local NAPA and look through the Gates catalog to find a hose that has the bends you need with the correct diameter(s), or borrow the hook and pull hoses off the wall that look like they might work, measure them and find one that may do the trick. I used to do that and end up buying a hose for some random car that would fit nearly perfect after cutting off that last foot, or similar. Anything except flex-hose, yuk.
