No end play and the wear pattern is right in the middle of the gear. I tend to agree with the spacer solution since I tightend the retaining bolt and upon inspection after the fialure, I was able to move the dist. by hand. You can't eyeball a .030" but the load could cause the failure. The cam is hydraulic, therefore, i am not installing the Bronze gear.
