At an Industrial Products briefing by Applied Industrial Technologies , the coatings made by Devcon, which can be used on concrete, were only 1 of 2 vendors listed in their catalog, the other being Loctite. AIP is a major nationwide supplier to
industry with sales of $1.9 billion
www.devcon.com
Epoxy Systems
Devcon Engineering Coatings epoxy systems are 100% solids coatings for rebuilding worn/damaged substrates and sealing/protecting new or repaired surfaces. Ideal for guarding against corrosion, erosion, chemical attack, abrasion, and wear, Devcon epoxy systems protect concrete, steel, and other substrates, and cure to smooth, seamless finishes that are potentially stronger and more durable than the original substrates.
_Name
Description
ARL 6000
A 100% solids novolac epoxy lining which provides superior protection of concrete, metal, and FRP surfaces against severe chemicals
CC 4000
A brushable epoxy coating for rebuilding worn areas less than 1/16" deep or protecting new equipment
CC 4000 Thinner
Consult Factory
CP 2000
A 3-component formulation for repairing and patching severely damaged or pitted concrete
CR 5000
A high-performance, high-density glass flake-filled sprayable epoxy coating
CRL 7000
A 2-component highly cross-linked oxirane polymer coating
CS 2000
A clear epoxy coating for priming, waterproofing, protecting, and sealing concrete, masonry, and ceramic surfaces
CT 3000
A trowelable, ceramic-filled epoxy repair system
CW 3300
A high-performance epoxy wearing compound with small and large high-alumina ceramic beads and silicon carbide chips
SL 1300
A 2-component, 100% solids epoxy coating for resurfacing, sealing, and protecting concrete floors.
Z9411 Primer
Z9411 is a 2-component, 100% solids epoxy primer that provides excellent adhesion to concrete, steel, brick, and most manhole construction materials.
Anti-slip additives are available
